DC Head
SHeiserman
03-02-2003 17:36:05
Any guesses at how much a head repair will be. The engine was overhauled years ago and they put an aluminum piston kit in it. Then they parked it. It sat outside for at least 20 years with nothing over muffler. Radiator still has antifreeze in it, but head is bone dry. The engine will rock back and forth, but not very much. 4 valves are stuck, I tapped them down, but they won't come back up. Head says 5505 on it. Two of the valves and rockers were covered in rust, but the rest were really clean. Just wondering what I'm looking at here.
Don Rudolph
03-02-2003 20:57:20
 Re: DC Head in reply to SHeiserman, 03-02-2003 17:36:05
Just had a head done. Valves are $42 each. Guides are 10 for intake, 12 for exhaust. $25 to install guides. $25.00 to disassemble and clean. $50 to grind valves and seats. $25 to reassemble.
These guys are considered reasonable. I also had them shave head for $25.00. DON
caseman-d
03-02-2003 20:01:12
Keep trying to work the valves. That might be all that is wrong with it or did you pull the head already. I would try using a good penetrant to use on the valves
SHeiserman
03-03-2003 03:19:38
 Re: Re: DC Head in reply to caseman-d, 03-02-2003 20:01:12
I've got about 50 cans of PB Blaster down the cylinders and all over the head, seems to work pretty good. Figured head is cracked and it will have to come off anyway. I'll keep playing.
caseman-d
03-03-2003 12:07:30
 Re: Re: Re: DC Head in reply to SHeiserman, 03-03-2003 03:19:38
Well if you used 50 cans of PB Blaster the chances are its running down past the rings. Did you by chance drain your oil. If you did then put the plug back in and dump more penertrant down. By draining oil you can tell if the fluid is going past the rings. Also you might pull the inspection plates of the side and look up the cylinders you should be able to see which one are wet. What makes you think the head might be cracked?
SHeiserman
03-03-2003 17:19:09
 Re: Re: Re: Re: DC Head in reply to caseman-d, 03-03-2003 12:07:30
I did drain the oil before I started. Penetrant is definitely getting past at least most of the rings anyway, just about to run out of inspection cover.I even looked up at the pistons. One of them was completely covered in green (presume antifreeze) and white. The PB Blaster cleaned it up quite well. I assume head is bad because of rust on the valves and piston. The bad looking piston had good looking valves above it, the bad looking valves had good pistons. That doesn't make sense to me. Why won't engine go all the way around?
Don R
03-03-2003 18:06:08
 Re: Re: Re: Re: Re: DC Head in reply to SHeiserman, 03-03-2003 17:19:09
Is it completely thawed out? The DC LP I brought back from Texas soon would not turn over because the hydraulic sump was completely full of water as well as the differential. Your head does not have to be bad. The head gasket could be blown or the head warped slightly to allow coolant to leak. Don't write it off yet.
SHeiserman
03-03-2003 18:23:14
 Re: Re: Re: Re: Re: Re: DC Head in reply to Don R, 03-03-2003 18:06:08
Never thought about water in rear or hydraulic sump. If it ever warms up I'll look to drain those. Of course I have no idea where hydraulic sump is. It was fairly warm when I pushed it in the shed, so that never occured to me. I haven't forgot about your ads, just haven't done it yet. Father in law had never even seen them, he thought they were pretty neat and made his own copies. I'll get them to you sooner or later.
Don R
03-03-2003 18:29:57
 Re: Re: Re: Re: Re: Re: Re: DC Head in reply to SHeiserman, 03-03-2003 18:23:14
Don't worry about it. I know how hard it is to get everything accomplished and usually it takes longer than anticipated. Thanks for keeping me in mind.
Believe me I was surprised when that DC that was free in Texas was tight in WI. Don
