Fan belt
LW
03-02-2003 14:15:08
I guess nobody knows how to change a fan belt on a David Brown, 1200A, Deisel, but thanks anyway..Lonnie
kydavid
03-02-2003 15:49:23
 Re: fan belt in reply to LW, 03-02-2003 14:15:08
Don't know for sure on a 1200 but on a 1210 and a 1410 (with front mounted hydraylic pump) there is a "fitting" that bolts with 4 bolts into the front of the crankshaft pulley. Take the bolts out, tap on the pulley, and work the fitting forward on the pump drive shaft. Then change the belt, or can pull the hydraulic pump and drives shaft.
kydavid
03-02-2003 19:34:37
 Re: Re: fan belt in reply to kydavid, 03-02-2003 15:49:23
Thank you for replying, I guess the best thing to do is get under it and have a good look, HUH.. I have all the repair books for it but they do not say anything about changing the fan belt..Again I thank you for replying-----LONNIE
