Stuck DC clutch
a question
Mike Schotte
03-02-2003 07:42:52
I've never messed with either of the wet clutches on my SCs or my DC-3. The clutch on the DC project is currently stuck- and I've been wondering about ways to unstick it without splitting the tractor.
I was thinking... since you have the side access plate to adjust the clutch- couldn't you just disengage the lock pin and try to rotate the clutch? I'm just wondering if you might have any chance of separating the stuck clutch disk by uncrewing it away from the surface it's stuck to.
This may be a dumb idea... but I thought I'd throw it out there and see what anybody with clutch experience thought.
-Schotte
Dale in Tx.
03-02-2003 12:54:03
 Re: Stuck DC clutch - a question in reply to Mike Schotte, 03-02-2003 07:42:52
Never heard of A wet clutch sticking,can you hear it snap in and out? if so mite try clutch out in 4th. gear and rock tractor, if can't feel cluch snap in or out clutch could be waded up then it is splitting time good luck. Dale in Tx.
C. Amick
03-03-2003 09:54:00
 Re: Re: Stuck DC clutch - a question in reply to Dale in Tx., 03-02-2003 12:54:03
My guess is that the clutch plate is stuck to the transmission shaft. Oiling it up good with diesel fuel or what ever certainly needs to be done first. Watch that spring loaded button on the pressure plate that you have to shove in to adjust the clutch pressure. It will stick in the "in" position and not come back out. Spray it good with some P.B. Blaster or something before shoving it in.
Mike Schotte
03-02-2003 12:59:59
Thanks for the tips, guys. I think I'd rather try the diesel trick in the clutch housing and then drain it out rather than circulating it all through the oiling system by running the tractor (if it was running, that is.)
To answer your question- you can't move the clutch handle at all. I think it's stuck in the engaged position.
The tractor isn't running yet, so rocking is the only movement trick that I can try for now.
-Schotte
John Saeli
03-02-2003 14:04:28
 Re: Re: Re: Stuck DC clutch - a question in reply to Mike Schotte, 03-02-2003 12:59:59
Mike; Even if the clutch plate was stuck to the flywheel, the pressure plate should pop back. With the clutch lever not moving I'd start there. If the handle itself is not froze then the sliding collar must be froze on the shaft. Penentrating oil for a while, then you should be able to get in there with a bar and start prying it. After the pressure plate is back then try some of the other suggestions on loosening the clutch plate if that is also stuck. Hope this helps, John. PS Did you get my e-mail yesterday?
Jim M
03-02-2003 11:53:23
I'd pull the pan and plasticgage the rods and mains and check the clearances. I'd pull the pump and take the rear cover off and check it out. Those pumps have a problem with the woodruf key shearing inside on the driven gear. The book says they are not serviceable but I've repaired several. Also pull the bypass valve out and check the seat and spring tension.
Jim M
03-02-2003 11:55:11
 Re: Re: Stuck DC clutch - a question in reply to Jim M, 03-02-2003 11:53:23
Sorry wrong reply should be for the 500 oil pressure question
L.lamp
03-02-2003 08:59:52
The sticking is usually cased by moisture causing rust to glue the clutch disc to the flywheel. I think I would get some diesel fuel or kerosene and shoot it into the pressure plate area and wait a few days then rock it in gear with the clutch disengaged to try to break it loose. The way the clutch is made you can't get into it without a split. It could be stuck by goey old oil. The diesel will loosen that up too. Leave the plug out at the bottom of the flywheel and change engine oil to make sure it didn't get into the oil pan. Backing off the adjustment may help.
Don R
03-02-2003 11:45:08
 Re: Re: Stuck DC clutch - a question in reply to L.lamp, 03-02-2003 08:59:52
Mike,
I don't know if this is smart or not but my old Case dealer told my dad about 35 years ago to drain the old oil out (make sure and drain the clutch as well) and replaced it with diesel fuel. Let it run for awhile and it may break free. Watch the oil pressure gauge. I have done this twice and it has worked both times. Don
