Vac carburetor settings
Robert P
03-01-2003 20:10:14
I'm a bit confused since I have been getting different answers from different articles. What are the settings for the idle mixture screw and the power mixture screw on a marvel-schebler TSX-114 carburetor (VAC tractor)?
Many thanks.
CASEPOWER
03-02-2003 06:26:32
 Re: Vac carburetor settings in reply to Robert P, 03-01-2003 20:10:14
There is no one setting that is going to be right. Turn them in all the way not bottoming them out tight then turn them 1-1/2 turns out. Start it up then adjust it from there. If there are no changes then you have something plugged in the carb.
Mike from Canada
03-02-2003 12:32:53
 Re: Re: Vac carburetor settings in reply to CASEPOWER, 03-02-2003 06:26:32
you may want to check the play in the throttle butterfly shaft bushings. that'll give you problems if theres too much play.
good luck!
mike
Robert P
03-02-2003 13:52:27
 Re: Re: Re: Vac carburetor settings in reply to Mike from Canada, 03-02-2003 12:32:53
Thanks for your advice. I will set the adjustment screws as suggested by CASEPOWER and the throttle butterfly seems ok. It should start the engine, fine tuning will come afterwards.
