Is a 2670 a good heavy tractor?
redwall
03-01-2003 05:42:54
I am looking for a heavy tillage tractor. There is an extra sharp 2670 for sale at auction in our area next week. So..... what do I need to look for? Are there problems, or weak spots? And what does this model have that is extra good.? Thank you in advance.
Jim Handke
03-02-2003 11:37:45
 Re: Is a 2670 a good heavy tractor? in reply to redwall, 03-01-2003 05:42:54
The heads are bored out for bigger injectors than the 2470. So if the engine is really juiced up, pulled hard, then shut down without letting it idle and cool off, the heads will crack between the injector and the intake valve(I think it's the intake). The powershift has an more clutches in the packs, so you don't have to worry about the transmission. You get good, cheap horsepower in that tractor.
John Saeli
03-01-2003 06:04:20
redwall; That 2670 is getting old, they were built in the 70's. If I saw an either can in the cab I'd stay away. The power-shift should be checked to make sure it backs up and works in all ranges. I like to crack the oil drain plug after the tractor has set and look for coolant. I also make sure the radiator is chuck full and while running look for bubbles. For it's power, 220HP on the shaft, the 2670 isn't really heavy, but dualed up makes a good field tractor. You don't get a lot of compaction. Here in N.Y. those tractors are selling cheap, under $10,000. Hope this helps; John
KirkIn Kansas
03-19-2006 12:26:30
 Re: Re: Is a 2670 a good heavy tractor? in reply to John Saeli, 03-01-2003 06:04:20
Amen to That John,
Yep, these 2670,s are one stud tractor,
Case is the only one I know that can get alot of HP,s out of a standard block like the 504 ci,
Theve used that block for yrs, and never had any kind of fault with it that I know of?
Also ,It,s built to work on,better than other makes Ive seen where you have to take it to the shop,and then they stab you in the back on labor,
Hey John,
You know those 970,or 1070,s,
Well,Im wanting one of those too,
I like the No Cab model,s,which were not as plentiful as the cab,s
Ive seen alot of the older brochure,s on the Desert Sunset,& Flambeau Red one,s,
and they look REALLY NICE ALL REDONE!
Talk to ya later ok,
kirk,
