EAGLE HITCH
TOM
04-06-1999 18:43:03
What kind of implements can you use on a eagle hitch? Can you use three pt. hitch implements?
TMAC
04-07-1999 19:17:08
 Re: EAGLE HITCH in reply to TOM, 04-06-1999 18:43:03
I bought a scrape blade,3pt boom, and scoop bucket for my VAS. Boom fit but the spacing on the scoop bucket had to be brought in and on the scrape blade it was to narrow and had to be widened(both set for 26"). A bit of a pain but I had a good welder do the work and the implements work great with my Eagle hitch now.
Tom
04-06-1999 20:53:05
What about the top bar(On a three Pt. Implement). You can't use that on an eagle? Or can you weld a bar under the seat?
dfoley
04-06-1999 20:14:41
you can use any three point implements that
will fit the hitch. mine has 24 inches between the
hitch points. just remember that the hitch is of a rigid type and has no sideward play at all.
most of the deere implements have 24 inch pins
so they work fine.
[email protected]
Lee Forbush
04-06-1999 21:20:36
 Re: Re: EAGLE HITCH in reply to dfoley, 04-06-1999 20:14:41
You can use any other CAT I three point hitch product. You can use the top link too but a case top link must be shorter than other toplinks.
