ID numbers
JERRY WHIPPLE
02-28-2003 10:08:24
I have a 1955 400 case gas and I need to know were are the engine numbers so I can order a overhaul kit.I believe case made 2 gas engines for this tractor the 251 cid and not sure about this early one maybe 188 cid. Thank you for your help
Jerry
Dale in Tx.
02-28-2003 15:59:10
 Re: ID numbers in reply to JERRY WHIPPLE , 02-28-2003 10:08:24
If your tractor is a 401 it has the 251 gas engine. the 400B is the small tractor and has the 188 cubic in. engine. The serial no. should be on dash on right hand side,if not the serial no. is stamped on the rear flang of engine on left rear just in front of clutch inspection plate,if doesn't have a cluch it is case-o-matic and is 400B.thus 188 cu. in. Dale in Tx.
Jerry
03-01-2003 06:48:24
 Re: Re: ID numbers in reply to Dale in Tx., 02-28-2003 15:59:10
Dale , thank you for the reply. I tis the Racine round nose 400 .
Have A GREAT DAY
Jerry
