Opinions of a Case 1030
Iowa Farmer
02-28-2003 05:33:59
I have never been around Case tractors and very few of them were in my area. I was wondering what their pros and cons were. Did they have any drive train problems? Did they have fast, responsive hydraulics? And also I was wondering if anyone has had a Westendorf WL40 or WL42 loader on one. Any help is appriciated. Thanks!
Bill
03-02-2003 10:44:46
 Re: Opinions of a Case 1030 in reply to Iowa Farmer, 02-28-2003 05:33:59
I am a JD man but those 1030s can kick butt at the tractor pulls
Tremayne
03-04-2003 16:33:11
 Re: Re: Opinions of a Case 1030 in reply to Bill, 03-02-2003 10:44:46
I have one with a turbo from a 1200 TK, 23.1 x 30 mains with fluid & 18.4 duals, and about 1100 lbs of front counterweight. Has almost a thousand trouble free hours like this. Pulled a 6 bottom in heavy Indiana glacier clay, had to start straight because the front wheels were constantly coming up. Have to watch the temp and let her idle for while before you shut it down. Like they said, keep the rad full & clean, oil in the differential & if you let it sit for a month or so,(especially in the winter) pull the motor drain plug to make sure water is not in there. The O-rings on the sleeves will seep. Especially in cold weather. I plan on de-tuning it some because I do not want to push my luck. Great old tractor!
Gary H. IA
03-01-2003 17:41:45
Have a little experience with Westendorf loaders on 30 series Case Tractors. If my memory serves me correctly Westendorf makes side rails that must be bolted on the frame when using this brand of loader. I remember we broke a Case Tractor in two with a Westendorf loader, but Westendorf stood the cost because they forgot to supply the frame rails. They cost extra, of course. I can't remember which model of 30 series is was as we had three or four of them. Good Tractors and dam good loader.
Don R
02-28-2003 22:51:13
A 1030 is a good tractor overall. However the radiator must always be kept clean or it will overheat and crack heads. Also keep her full of hydraulic fluid or the reverser gear may lock up and do nasty things inside if it gets way low.
joecool
02-28-2003 17:41:59
Dad,(a Case service rep in 60-70's), was recently telling us war stories and one was about how 1030's temp gauges were improperly calibrated and that they changed out alot of temp gauges to solve the "overheating" problem.
Jim Handke
02-28-2003 06:55:13
Dad and I each had a 1030. The radiator wasn't quite big enough and they would overheat, Dad's 930 never would. Same tractor, bigger pistons in the 1030. Hydraulics were good for those days. Won't compare to the one's today. Will be more than ample for a loader. Each of our's had the ring gear and pinion shaft replaced. We reduced the backlash a little when we did that and they never gave us any trouble after that. The 930 will start better in colder weather. They had cast iron pistons instead of aluminum that the 1030 had.If they sit outside, rust builds up in the brakes and ruins the pads. Keep it inside and you won't have that problem.
Kennyp
02-28-2003 06:40:44
You'll probably get vairing opinions on this...I had a 930ck and my neibour across the fence had a 1030ck. They are all most the same tractor, except for engine power.The 930 was probably the nicest tractor I have ever owned. Some faulted it for lack of power compaired to like M&M. I ran it 6 years and came close to my money back at trade in. The friend was all ways asking me if it over heated. It did not. I have all ways wondered if he luged his 1030 too much or maybe it only had one fan belt. My 930 had a double fan belt and it was OK. Hope this helps.
