Changing trike to wide front end
Don
02-27-2003 17:01:18
I have 1946VAC ser# 5059992 what can be put in it and if I can where can I find it Thanks Don
mj
03-02-2003 18:18:25
 Re: Changing trike to wide front end in reply to Don , 02-27-2003 17:01:18
third party image
Here's a VAC trike someone changed to a widefront (VAO style) and got the steering to work with the trike steering gear by moving the tie-rod to the front of the axle. I didn't focus on the steering modifications on the day I took the photos but the inset pic shows the steering arm coming out of the front of the bolster; they must have cut off the front wheel-mounting fork and welded an arm on to connect to the front mounted tie-rod. That way they didn't have to change the steering gearbox. Wth the stock VAO front the tie-rod runs behind the rear axle and the draglink connects to the left spindle arm. The VAO used a 12" center to center Pitman arm while the VACs used a 9 incher. If you can find a VAC adjustable widefront with the bolster then you don't have to worry about the steering going the wrong way as the linkage in the bolster takes care of that when going from a trike or narrow-front.
mj
03-02-2003 19:07:39
 Re: Re: Changing trike to wide front end in reply to mj, 03-02-2003 18:18:25
third party image
Here's a VAO widefront and bolster. The draglink has been modified with a 'dogleg' for some reason. The Pitman arm is 12'" long (ctr-ctr) but a 9'" may work and would give easier steering. This set-up turns right when the Pitman moves to the rear.
mj
03-02-2003 19:13:23
 Re: Re: Re: Changing trike to wide front end in reply to mj, 03-02-2003 19:07:39
third party image
Here's a VAC adjustable widefront bolster pic. These turn right when the Pitman arm (9" c-c) moves forward.
James
02-28-2003 04:20:24
Any wide front for the VACs is very hard to find in my area. There has to be thousands with the narrow fronts. But i know a guy who changed one over and like D Kase said you need to get the gear box parts also.
DKase
02-27-2003 17:42:51
I put the front end from a VA on my VAC. It all bolts right on, but the gearbox has to be changed with the front end or it will steer backwards! I built a belly mower on mine and the wide front works better and turns shorter. I don't know where you could look for a wide front. An adjustable one would be harder yet to find.
don
03-02-2003 15:35:41
 Re: Re: Changing trike to wide front end in reply to DKase, 02-27-2003 17:42:51
you said it bolted right on did you have olny a single wheel or two. I have two with 4 bolts holding on the pedistal is this what you have.
Don
02-28-2003 12:27:04
Thanks for info does stering rod from the old box go right on new one
mj
03-02-2003 18:58:36
 Re: Re: Re: Changing trike to wide front end in reply to Don, 02-28-2003 12:27:04
I believe it does.
mj
02-28-2003 14:42:56
I've got 2 trikes, an adj. wide, a non-adj. wide not installed and a trike converted to an adj. wide. I can get some specifics for you when it quits snowing a bit! It's about 2 inches per hour right now.
Minn.Norske
02-28-2003 16:09:57
 Re: Re: Re: Re: Changing trike to wide front end in reply to mj, 02-28-2003 14:42:56
I made a wide front on my vac. I took the rear axil from a case combine including the hydraulics. Narrowed it to the width i wanted now i have a wide front with power steering. I also took the geared steering of the tractor and put the one from the combine on it. Works great for mowing etc.I had a factory wide front but didn't like it
mj
02-28-2003 19:34:06
 Re: Re: Re: Re: Re: Changing trike to wide front end in reply to Minn.Norske, 02-28-2003 16:09:57
Want to sell the one you didn't like? E-mail me.
