Has anyone pulled the caseomatic, replaced clutches?
John in IN
02-26-2003 10:44:13
I have problem with my 830 caseomatic: grinding when trying to shift into gear. And won't pull itself up hill without shifting down. Test clutch pressure and it seems to have good pressure. Pretty sure it needs new clutches. Has anyone tried this themselves? If so would like some advice like the best way to get the Torque converter unit out, and anyones experience removing and replacing.
turbo
02-26-2003 20:47:47
 Re: Has anyone pulled the caseomatic, replaced clutches? in reply to John in IN, 02-26-2003 10:44:13
The clutch pack at the rear of the case-o-matic is engaged for direct and case-o-matic. Direct pack is one plate in the Torque converter which locks the converter solid. The rear pack, which transmits all the power in both speeds and is disengaged with the foot pedal,is most likely is slipping all the time. Warpage of plates causes shifting problems. There is a special removal fixture but I never use it. After you split the engine, slide the live shaft out forward part way and use it to remove the case-o-matic transmission. You have to remove the control valve housing on the left side to remove the bolts and use some long threaded bolts to lock the clutch pack together. I think the housing on the right side has the filter and pump so it has to be removed also. I know that there is more to it but it has been several year since I have removed one and this is from memory. An I&T manual gives you enough information to repair the unit. Hope this helps.
John
02-27-2003 06:29:44
 Re: Re: Has anyone pulled the caseomatic, replaced clutches? in reply to turbo, 02-26-2003 20:47:47
Do you use the shaft and pull it out by hand? Or do you use something to pull it out with?
turbo
02-27-2003 18:32:14
 Re: Re: Re: Has anyone pulled the caseomatic, replaced clutches? in reply to John, 02-27-2003 06:29:44
You may need 2 persons, or a floor crane.
