Hey Casepower, your right
wheat straw
02-25-2003 14:29:25
After a second attempt, I was able to get an e-mail through to Mr. Erb. He said that all VAH tractors had the drop axil outside the diffirential. Somebody had a confused VAC on E-bay way back when. Just wanted to set the record straight.
Thanks guys. Have a great day.
Wheat Straw.
CASEPOWER
02-25-2003 17:39:01
 Re: Hey Casepower, your right in reply to wheat straw, 02-25-2003 14:29:25
There was or still is one on E-bay with a single front wheel. The fork is tall and it looks original. I've never seen one like that..
mj
02-25-2003 19:21:56
 Re: Re: Hey Casepower, your right in reply to CASEPOWER, 02-25-2003 17:39:01
Right now I've got one complete but not running (yet)single-front VAC, another VAC parter with s-front and a single-front bolster, fork and wheel assembly. I think that these are more common in areas like mine where they've been using ditch irrigation for a long time. I'll try to post a photo in 'Tractor Photos' in the next day or so. In the Case manual I have they show a single front but it is for the later VAC-14 style steering where you just unbolt the wide front and bolt the single or narrow front assembly (they show both) to the shaft plate. The ones I have, however, require the entire bolster to be swapped as they fit the early VAs with the side steering arm.
CASEPOWER with VAH picture
02-25-2003 20:09:41
 Re: Re: Re: Hey Casepower, your right in reply to mj, 02-25-2003 19:21:56
third party image
This is the only VAH single front I have seen. It looks original.
mj
02-26-2003 06:32:19
 Re: Re: Re: Re: Hey Casepower, your right in reply to CASEPOWER with VAH picture, 02-25-2003 20:09:41
Holy Smokes! Last evening I was thinking you were talking about a standard single-front VAC (I knew about the widefront VAH on eBay) then realized that you were talking about an H! I've never seen one until I saw your post with photo. Wonder what other strange combos are going to show up? Thanks for the photo!
CASEPOWER
02-25-2003 19:52:08
I have a single front VAC. The one on e-bay was a single front VAH highcrop and the fork was much taller then the VAC. I will post a picture..
mj
02-25-2003 15:01:14
I remember that deal. In the meantime I had a thought (always dangerous!) about something that I came across over the years. My first VAC has the wide adjustable front (pre-tubular axle) like the one shown on the VAH in question but with shorter spindles. I got another VAC with the same setup last year but it was obvious from the mis-matched paint that someone had changed it from a narrow or single-front to the wide front. All of the sheetmetal, radiator etc. was removed for a restore that never happened. In the re-assembly process I noticed that the front pulley did not have the relief notch for fan belt removal/installation as my first one has. If the tractor in question HAS the notch then it is fairly certain that it had a wide front when it came off of the assembly line as I haven't seen this notch on any factory single or narrow front tractors.
