630 CASE
TIM C
02-24-2003 16:13:28
MY FATHER PURCHASED A 630 CASE THAT DOES NOT HAVE THE NORMAL SERIAL NUMBER TAG. IS THERE ANYWHERE ELSE ON THE TRACTOR THAT WILL SHOW YOU THE SERIAL NUMBER? THANKS FOR ANT HELP YOU CAN GIVE.
Jim C
02-26-2003 17:53:12
 Re: 630 CASE in reply to TIM C, 02-24-2003 16:13:28
I looked at a 630 a couple weeks ago. It had the serial number stamped on a rectangular shaped, raised area on the engine block. Right side of engine just above starter. I noticed this because my manual says that my 530 loader tractor is supposed to have a number there too but, mine does not have it. Hope this helps.
Dale in Tx.
02-24-2003 18:19:49
The serial #is stamped on engine flang at rear of engine,useually left side. Dale in Tx.
