Re: case magneto
matt c
02-24-2003 13:46:37
i have a 48' case sc. looking at the dash there is a magneto kill switch. mine is missing. but looking at my magneto i don't see where i would connect a wire to it, to ground it. any info is great. thanks
C. Amick
02-27-2003 05:36:41
 Re: re: case magneto in reply to matt c, 02-24-2003 13:46:37
I looked at my Case mag. There is hole in the cap between the bottom two mounting screws. I think that this is where the tab was originally mounted. I ran a kill wire through this hole into the mag. Hook the kill wire to the post with nuts on it that is part of the points. The NAPA part number for the kill switch I bought is PP6354. It's not an exact match, but it looks better than those switches with the plastic pull knobs.
C. Amick
02-25-2003 14:40:07
If the kill wire tab is missing, you may have to either make one or just run the wire into the magneto case. NAPA Auto Parts sells a 6 volt switch that very closely resembles the original Case switch. The metal pull knob is almost identical. This switch has two posts though, so you will have to run one to ground. I can get you the NAPA Part Number, if interested.
matt c
02-25-2003 15:47:48
 Re: Re: re: case magneto in reply to C. Amick, 02-25-2003 14:40:07
what if anything is that tab connected to on the inside? i cannot seem to pull it out. is there a nut on the inside. the reason i ask is, the tab itself comes out of the plastic cover. it would somehow have to ground to something? plastic? hope you can follow. also if you have that part # for the switch that would be great
Mike Schotte
02-25-2003 15:18:36
Myron,
I'd be interested in that switch part number. It's got that really small knob like the original?
-Schotte
Hanovertom
02-24-2003 18:09:18
Matt, I am also working on a CASE SC 1948 model
TOM
RoyG
02-24-2003 14:36:48
If it is a case Mag. there will be a post with a nut and a short strip of metal on it about the center of the mag on the bottom back side. This is where you hook your kill swith to.
