Hi (should I call you Super?) I bought a 5-gallon carbuoy of Evapo-Rust when it was first introduced to the market 1-1/2 years ago. I believe the cost was around $86.00 plus shipping. The product works well, but it's not super quick. The part has to be free of grease or oil, but it does the job. I was able to free up the pipe handle on the hand crank of my SC after a 24 hour soak. I was able to crack it loose with a pipe wrench after soaking it for half a day, and it spun freely by hand after the second soaking. One gallon of the product was supposed to treat 300lbs of rusty metal, but I don't think I got quite that much out of it. Of course, I was doing mostly sheet metal- and you can pack a lot of rust into all that surface area. Every time I've contacted Evapo-Rust with a question or problem, I've had the inventor of the product personally return my phone call. When I questioned the longevity of the product, he told me that they had improved the formula since it's original introduction, and he told me to call him again when I wanted to order some more. I've learned that the product doesn't work as well on rusted items that have burned in a fire, and certain types of rust like magnetite are harder to remove. However- using this product is a 1000 times better than trying to wire wheel or sandblast the rust away. I can't imagine how much work and time it saved me on that grille. I would recommend the product, and would use it again. I like the fact that it is non-toxic and can be poured down the drain or in the ground when you are through with it. It also has no fumes or chemical smell. I tried the electrolysis method once I had exhausted my supply of Evapo-Rust. It works good, too- but it's definitely not any quicker. I think I would continue to use electrolysis on heavy cast iron parts. (see my manifold photos.) Let me know if you need any more info. (I'll e-mail you a picture of the hand crank that I dipped.) -Schotte
