Hi-Lo TCH fluid and Type A fluid in 830
Tom in Mo.
02-23-2003 20:30:20
I have a 1965 830 CK Dual Range transmission. This is not a Caseomatic. The operators manual says to use Type A automatic trans fluid or Case Hi-Lo TCH. I searched the archives and couldn't get a definite answer on cross references.
Is the old Type A automatic trans fluid now Dexron?
Has the Case Hi-Lo TCH been replaced by Case Hy-Tran?
Is the Universal Hydraulic-Transmission fluid you get in the farm supply stores a safe and usable substitute? Thank you for the input.
nwkansas
02-24-2003 17:04:39
 Re: Hi-Lo TCH fluid and Type A fluid in 830 in reply to Tom in Mo. , 02-23-2003 20:30:20
Dollar General store in my town keeps type A on the shelf for $.75 per quart.
Tom
02-24-2003 09:17:22
Recommend you pull the spec number of the latest case fluid. Then go to Pennzoil website and pull the specs on their Hydra-Tranz fluid. It is for hydrolic, trans, rear-ends, wet brakes, final planetary drives. Detailed specs give spec numbers for all tractor makes. You can see if it meets the Case spec numbers. Using spec numbers is more acurate than using "product names" IMHO. From the Pennzoil homepage select car/trucks and then go deeper to download full Hudra-Tranz specs. Tractor Supply sells it for $29.99 per 5-gal pail. Good luck.
K-Mo
02-24-2003 08:09:25
I use the Universal Fluid in everything. One of my tractors is a 630 Case-O-Matic and the Case-O-Matic fluid is also used for the remote hydraulics. If different tractors are used on the same hydraulic implements such as a disc cylinder, fluids from one tractor become mixed with the other. Since these tractors are still running after 35-40 years, I figure it's not worth getting too wrapped up in specific fluids types. At least with the same in all tractors, I'm not mixing fluids.
Just my two cents.
K-Mo
Kennyp
02-24-2003 09:06:47
 Re: Re: Hi-Lo TCH fluid and Type A fluid in 830 in reply to K-Mo, 02-24-2003 08:09:25
Same thing here. It is common of all farmers I know of, to use universal from many diferent companies. Never heard of any problems. I might use ATF in a small tractor in cold weather tho.
Roger
02-23-2003 22:53:13
Hi Tom, Case discontinued the TCH a year or so ago, they now recommend Hy Tran Ultra. I'm running it in my 930's & no problems so far. We've been running Dexron in the 830 LP for a long time. I don't know about some of these "universal " fluids out there, maybe they're ok but I'm not sure.....Roger
Tom in Mo.
02-24-2003 04:47:31
 Re: Re: Hi-Lo TCH fluid and Type A fluid in 830 in reply to Roger, 02-23-2003 22:53:13
Thanks Roger. I thought the type A was the forerunner to the Dexron family but wanted to verify. My nearest Case-IH dealer is over an hour away each way so I will probably try the Dexron III and hope it does fine. The old fluid came out white as milk.
My 830 CK is also an LP fuel.
JimmyG
02-24-2003 16:51:01
 Re: Re: Re: Hi-Lo TCH fluid and Type A fluid in 830 in reply to Tom in Mo. , 02-24-2003 04:47:31
Don't use a dextron 3. If you are going to use dextron, get a #2 the #3 is a viscosity of 0w20 and gives no real lubrication. Good mechanics are adding lubricant enhancers to the #3, a #2 is a 5w20 and will run cooler and give a more stabile Vis. I personally would go with the universal type hyd. oil over dextron. They generally are a 10w30 or in case hytrans case a straight 20w. and will give a much better protection. Your fluid was white due to the water contamination. thats why despite what some will say you really do need to change out these fluids at semi annual. they just like motor oils have additives that do wear out and the acidity of the fluid does increase and will cause wear and Viscosity breakdown which will cause increased system heat and in these systems is your main source of damage is heat and water ingretion
just my opinion Jimmy G
