Case tractor
Don Pike
02-23-2003 18:18:55
I just purchased a Case tractor DC at an auction. I cannot find the model number. Where can I look? Also, cannot find out how to check the oil. Cannot find a dipstick,
Will appreciate any help.
Don Pike
DaleTx
02-23-2003 18:43:07
 Re: Case tractor in reply to Don Pike, 02-23-2003 18:18:55
The serial no. should be stamped on left side next to bell housing on block the year and model can be figured from there.The two 1/8in plugs on left side of oil pan is the hi & low for your oil dipstick,pretty modern isn't it. DaleTx.
Mike Schotte
02-23-2003 18:42:55
Don't forget that you can get the serial number off of the flange of the engine, too. (Helpful if the dashboard serial number tag is missing.)
-Schotte
SHeiserman
02-23-2003 18:34:56
The serial # is behind steering column under battery tray. There are two plugs on oil pan for checking the oil. As far as which model DC, I believe that depends on which front end you have. If you don't mind me asking, what did you have to give for it? They seem to be reasonably priced whenever I've looked. Happy hunting.
