Ditch shot for Les...Fortunate
mj
02-23-2003 18:02:33
third party image
Okay, everybody here is, I hope, my first message with image attached! This a shot that stesses the need for good welds if you do the 'Case VAC E-Z steering' modification!
Ralph NH
02-24-2003 17:03:41
 Re: Ditch shot for Les...Fortunate in reply to mj, 02-23-2003 18:02:33
Just had to comment on that ditch. That is some impressive to us fourth-generation farmer/loggers here in New Hampshire. There's nothing like that around here, even though there are hundreds of ravines, gullies, and waterways. We don't have the wide-open spaces and the massive system of man-made irrigation. Our neck of the woods is mostly woods and mountainous terrain. I enjoyed the brief history you gave. Thanks again.Les' little brother Ralph
mj
02-24-2003 17:43:47
 Re: Re: Ditch shot for Les...Fortunate in reply to Ralph NH, 02-24-2003 17:03:41
When the pioneers from the east got out here it was as though they had no limits or restrictons on their projects to make this land productive. Suddenly, they were able to put all of their experience and knowledge to work! I didn't mention the Gunnison Tunnel which is probably the most inspiring part of the system in this area. The link will give some history on that and link you to more.
Ralph NH
02-27-2003 04:52:51
 Re: Re: Re: Ditch shot for Les...Fortunate in reply to mj, 02-24-2003 17:43:47
Thanks mj. That is fascinating history!!
Les
02-24-2003 05:18:20
Good grief! I suppose you have to have man made things wheere you are to civilize the land. I'm sure it has been full of water at times, too. Right?
mj
02-24-2003 06:40:48
 Re: Re: Ditch shot for Les...Fortunate in reply to Les, 02-24-2003 05:18:20
Actually, there is only one big culvert coming into it at the head end (100yds. in front of VAC). As you go downstream there are a dozen or so small tiles that drain the fields at the 6 ft. level most of which run about 1/4 full all the time. The ditch itself runs about 3 miles where it hooks into a bigger one which eventually dumps into the river. I'm only real familiar with the first mile and at that point, when everybody is running all the water they're allowed, it gets a couple of feet deep. The reason the ditch is so deep is so that the fields will 'sub' to that depth and keep the salts in the soil washed down out of the top layer that gets farmed. This area was, around 1900, marshy underneath and desert on top! The canals brought the water in and the drain ditches allowed the soil to dry so that the canal water could be directed for cultivation. The whole system is pretty massive and starts with a reservoir some 90 miles away near timberline in Taylor Park which is N.E. of Gunnison, Colo. and eventually ends in, well, Baja! Each system from Taylor to California gets this water in time. If you ever get out this way it's worth the time to study the system a bit!
mj
02-23-2003 18:47:50
third party image
Now that I can get pics in, here is the 'E-Z steering' modification for VACs- Add 3 inches to steering arm as shown by white section. Make sure welds are first rate! This modification, along with an 18" steering wheel (some VAs had 16 inchers), will greatly reduce steering effort.
