Help with injector pump
Scott Roland
02-22-2003 16:32:01
I have just finished rebuilding today a 701b case with a 267 diesel engine. The engine runs great but the pump is putting alot of diesel in the oil. The tractor sat for about 3 years before i bought it. Any suggestions on what to do other than having the pump rebuilt Thanks for any advice Scott
Butch/ OH
02-23-2003 09:34:41
 Re: Help with injector pump in reply to Scott Roland, 02-22-2003 16:32:01
Your 701 has either the American Bosch rotary pump or a Robert Bosch in line pump and I suppose that both could be leaking, but you will have to take the pump and have it rebuilt.
Kennyp
02-22-2003 17:48:21
My mmory is bad, but there was one make of pump that would do this if the fuel filters were plugged. I had one on an old M&M diesl.
twopop
02-22-2003 17:11:09
dont know what kind of pump is on the 701,but it probably doesnt need rebuilding ,except for replacement of the seals between the pump and engine,some of these are umbrella looking seals that install on the driven pump shaft.
Gary
02-22-2003 19:07:10
 Re: Re: Help with injector pump in reply to twopop, 02-22-2003 17:11:09
Two POP is probably right. I ran into this on a 207D engine on a 580? backhoe. It put enough diesel into the oil that it siezed. It was idling at the time, didn't do a whole lot of damage.BEFORE you pull the pump, rotate the engine till the timing mark lines up in the sight window on the pump, then pulll the battery cables off so that no one rotates the engine before you reinstall the pump. Makes lif a lot more simple. When you put it back on and get it bled and are ready to bleed the injector lines, pull the intake hose and place your hand over it while you spin it to get the air out of the injector lines. No intake air, no compression! Saves your battery and ypour starter.
