Joe (Wa) hydo loader
Kennyp
02-22-2003 15:51:40
Joe, you said you were running a loader off of the tractor hyd system. I am putting one on my 300. Qustion: Did you run it through the built in valve -remote connection- and then to the loader controls? Or did you go to pump outlet some where under the tin work? My 300 has the lift and one remote connection.
Knnyp
02-23-2003 10:34:21
 Re: Joe (Wa) hydo loader in reply to Kennyp, 02-22-2003 15:51:40
Thanks fellows. I have a little loader I made for a garden tractor, but couldn't keep the back wheels on the ground. Am working on mounting it so it will be quick detatch to the 300.
John Saeli
02-23-2003 10:14:35
Kenny; Saw your post, I put a loader on my "630" which is the same as your "300", I think. I plumbed it so it would be easy to take on and off if I wanted. I came to the remotes in the back for the bucket, CASE quick connects of course. For the loader, which didn't have down pressure, I put a Tee in the line going to the Eagle Hitch. On the line going to the loader I put a diverter valve so I could use the Eagle Hitch if I wanted. Works well. John
Joe (Wa)
02-23-2003 10:04:54
Kenny, supply & return hoses for loader valves are connected to the ports on the upper control unit interlock block. Joe
