Gene Rizzo
02-22-2003 12:00:36
How do I go about identifing this Case, It has a 12inch. clutch? The numbers on the block are 6400-A just under the firing order of the gas , 4 cyl. tractor. On the other side there is another Number 643 3. The transmission has the numbers 6480-A. There are no serial number on it, I don't know what year or model it is. Can some one help me out, need to do a overhaul on engine.
Gene
02-22-2003 20:11:40
 Re: Help Identify in reply to Gene Rizzo, 02-22-2003 12:00:36
I don't think it has a brake on PTO, seems like you just pull lever back and it starts, pull lever foreward and stops. The lever is on the left side. To me this tractor might be an orchard type because it is low to the ground. The radiator cap is under a flap, an wide front end does not adjust.
Butch/ OH
02-22-2003 16:09:29
The tractor is a 400, or more specificly a 411. It has a 251 cu. in. engine. The 400 series was produced from 1955-57. There are some features that could narrow down the year produced, but I'm not positive what they all are. Does the PTO have a brake position on the lever?
Thad
02-22-2003 13:04:01
Sounds like you have a hundred series tractor. Which has the 251 cubic inch 4 cyl it should have two seprate heads also. Could be a 400 thru 800 hope this helps.
Gene Rizzo
02-22-2003 13:52:12
 Re: Re: Help Identify in reply to Thad, 02-22-2003 13:04:01
Thanks Yes it does have two seperate heads. Is there any way to find out,what model and year, so I can get the engine overhaul kit for it.
CASEPOWER
02-22-2003 12:56:25
All I know is that my 1960 parts price list says one is a block and one is a case and one was $224 and the other was $200. They made it before 1960. Maybe someone else can tell you more..
