Chain drives question
head question
hunter
02-22-2003 04:56:20
Anyone know what if any is the difference between chain drives in the following tractors.
C,L,S,D,LA,500,600,900,930.
Are they all the same?
Heads - are the heads interchangable between?
C and D
L and LA
Mike Schotte
02-23-2003 18:37:45
 Re: chain drives question - head question in reply to hunter, 02-22-2003 04:56:20
I can't speak to the size differences between models- but I can tell you that the drive chains are massive.
Take a look at this photo of a Model CC that CASEPOWER is working on:
third party image
-Schotte
Brent
02-23-2003 01:35:56
Yes, you can break a chain - did it with the SC. I don't remember what chain it was - 120HB(?)
It's obviously extremely heavy duty, but it can break. And, towing a tractor with a broken chain isn't a great idea. The only thing that saved the transmission case was the mud and straw that collected around the stuck tire as the tractor was being pulled, like pulling it on a sled.
John Saeli
02-22-2003 16:26:04
Well, I looked in 3 books, The pitch on the chain for the "L" was 1 3/4"; the "900" and the "930" used a 2" pitch chain. The chain for the "S" series and "D" series was considerably smaller, and I'm sure the "S" chain was smaller than the "D" chain. Yes they would break a chain, and if they did, of course the tractor wouldn't go. If you towed it it would stuff the broken chain down thru the transmission housing. I have seen it.
Richard
02-22-2003 11:46:36
I thank the R ,RC is the only one with a small chain all the rest the same .Never heard of any one braking one.
Roger
02-22-2003 10:22:18
I have a '63 930 LP six speed that has #160 chain in the final drive, I'm pretty sure the smaller one's like the SC & DC has # 120 in them
John Saeli
02-22-2003 09:22:19
Hunter; Common sense tells me the larger the tractor, the heavier the chain. The parts book will tell for sure. If I get time I will get back, but I know an "S" chain is not in a 930. John
Mark
02-22-2003 06:47:08
I know the DC and L tractors use a different guage of chain. I don't think the sprockets will let you interchange them.
joecool
02-22-2003 06:08:06
Case used the same size chain in all chain drives from c up through 930, shows how strong chain are. C heads will fit on D or DC, vice versa, L will fit on LA but LA has better comp. and flow.
caseboy
02-25-2003 11:01:12
 Re: Re: chain drives question - head question in reply to joecool, 02-22-2003 06:08:06
we have run d's, L, la, 500 and 930.
c and d are same. l, la and early 500 same.
late 500, 600, 900, early 930 same.
late 930 gear drive.
i have the sizes if you need them
david
[email protected]
