VAC E-Z Steering
mj
02-20-2003 18:52:39
One of my VACs was modified by a previous owner to provide 'power' steering. You can use a spinner knob on this one!
roro
02-26-2003 12:36:01
 Re: VAC E-Z Steering in reply to mj, 02-20-2003 18:52:39
Greetings,
I appreciated the pictures. My 1956 VAC 14 is long overdo for a steering overhaul,ie worn U_joints, loose steering box. Do you believe this modification will
work on my tactor, since the pictures indicate a different set-up than on mine? Is the steering box difficult to overhaul-adjust? Thanks for any feedback.
roro
Les...fortunate
02-21-2003 08:35:04
Yep, doing both of those things increases your mechanical advantage. I bet there's a big difference.
Like you say, I hope that is an A-1 weld.
mj
02-21-2003 15:46:14
 Re: Re: VAC E-Z Steering in reply to Les...fortunate, 02-21-2003 08:35:04
The only time I really wonder about that weld is when I go out the back gate and have to turn left or right OR end up in the drain ditch which is about 20 ft. deep. Other than that I have complete confidence in that unknown weldor, whoever he was!.....Ya know, I'm not using that VAC right now and Magnaflux CAN be a good thing....right?
Les
02-22-2003 15:32:46
 Re: Re: Re: VAC E-Z Steering in reply to mj, 02-21-2003 15:46:14
A twenty' deep ditch??? Good grief! Sounds more like a canyon.
A tractor friend of mine lives right next to a railroad cut which has about a 20' drop. I'd hate to lose control of a tractor and end up down on the tracks. There's no fence or anything.
mj
02-22-2003 20:09:09
 Re: Re: Re: Re: VAC E-Z Steering in reply to Les, 02-22-2003 15:32:46
Yeah, it's about 20 feet deep....a drain ditch for the irrigated fields we have here. I need to take some pics of it soon because my neighbor is going to put pipe in the bottom of it and fill it in sometime this spring. He's putting in a center-pivot and will farm over the former ditch, I guess. When I get some photos I'll post one so you can get an idea of what it looks like.
