Hydraulic fluid check?
Lanette
02-20-2003 12:10:24
We have a 1945 Case Va tractor. The manual that we have for it does not show where to check for the hydraulic fluid. When the back blade is engaged to lift it lifts but very slowly.
Can not see any bolts to check fill level.
Can anyone advies?
Thanks
C. Amick
02-21-2003 12:27:30
 Re: Hydraulic fluid check? in reply to Lanette, 02-20-2003 12:10:24
Another reason it could be slow is air in the system. There is a brass bleed thumb screw located toward the tractor belly. Loosen it and cycle the hoist up and down a few times with the tractor running to get any air that might be in the system out.
Ross
02-20-2003 20:06:38
Lanette, There are two different hydraulic systems on the Case VA. If your tractor is a 1945 it will be a high pressure pump located on the belt pulley shaft. There is a large nut on top of the belt pulley with a square bolt in the large nut with a bayonet style dipstick for checking the fluid level. If you have a later VA with the pump on the govenor then the hydraulic resevoir is in the torque tube.
Ross
Steve Lehman
02-20-2003 18:04:24
The fill plug should be on the left side on the torque tube (it has a square head). You just fill it to the bottom of the hole. I assume from the year that this has the small cylinder on the right hand side, rather that the Eagle hitch. If you need parts for the cylinder, they should be available at a CaseIH dealer. I just picked up a seal for my 1950 VAC with an Eagle hitch for about $35.00.
Lanette
02-20-2003 18:28:45
 Re: Re: Hydraulic fluid check? in reply to Steve Lehman, 02-20-2003 18:04:24
another question....
the "torque tube" ... in your response you said that the square nut was on the torque tube...
Roger found the square nut on the left side of the tractor down below the steering column, is this the torque tube ?
Lanette
02-20-2003 18:22:09
thanks for the info, Roger did find that "like"
bolt on the left hand side this afternoon and said that it smelled like hydraulic fluid.
