DC sleeves/piston/rings
Eric
04-05-1999 18:17:55
Need to find after-market pistons and sleeves. Case dealer wants 200-250 dollars a hole. Only paid 200-300 for each tractor. Have a 47, and two 49's. Have others so I rob parts off these. And if anyone knows how much the high compression heads sell for or even the std heads I'm listening. I know the sp-12 combine had DC motor does anything else use the same piston sleeve setup.
Tim
04-06-1999 05:52:47
 Re: DC sleeves/piston/rings in reply to Eric, 04-05-1999 18:17:55
I have four new 4" DC pistons for 50.00 each.
Eric
04-06-1999 09:18:10
 Re: Re: DC sleeves/piston/rings in reply to Tim, 04-06-1999 05:52:47
Where are you located? Do you have rings too?
Tim
04-07-1999 05:44:51
 Re: Re: Re: DC sleeves/piston/rings in reply to Eric, 04-06-1999 09:18:10
Located in Creston Ohio (I can ship UPS) The pistons do not have rings.Thanks Tim
Lee Forbush
04-05-1999 21:50:38
I think that Power Seal has made the old M&W's available for the DC case. I think that i heard that they are about $600 for a set of pistons, sleeves, rings and wrist pins.
Eric
04-07-1999 08:58:20
 Re: Re: DC sleeves/piston/rings in reply to Lee Forbush, 04-05-1999 21:50:38
How do I get a hold of them and where are they located?
Lee Forbush
04-07-1999 21:21:05
 Re: Re: Re: DC sleeves/piston/rings in reply to Eric, 04-07-1999 08:58:20
The number for power seal is !-800-627-7171
