DB 996
Charlie
02-17-2003 05:43:35
I've noticed the power steering on my 996 has been squeaking a bit and I am having to top up the oil fairly regularly.
Not being mechanically skilled would it be advisable that it is easy enough for me to investigate the problem which i guess is a seal gone somewhere in the pump, or should I just put up with it for the sake of a pint of oil a week?
I also notice that the draw bar has been bolted in position but it looks as though it used to have some sort of connecting rods or other to make it into a pickup hitch. Does anyone know where I could see a picture of the back of one of these so that I can see how much I am missing? Haveing a pickup hitch would make life alot easier - it would be great if I could dispense with jacking up the trailer everytime I need to hitch/unhitch!
Thanks in advance for any suggestions.
Charlie
Jimc
02-21-2003 10:30:48
 Re: DB 996 in reply to Charlie, 02-17-2003 05:43:35
You will get the parts for the PUH from Albert Hirst in HolmFirth Yorkshire . He has new parts for both types of PUH. 885`s are different. Early 996 pre Qcab had rigid rods and Qcab models had chains. Jimc
Jimc
02-21-2003 10:30:38
Brit. 1
02-17-2003 06:22:53
the pick-up hitch has been on tractors in u.k. since the 1950s(ferguson te20) all makes and models of tractors are available to have this fitted. the ability to hitch to trailers and other trailed equipment then driving away without leaving the tractor seat is one of the greatest and safest inventions of all time in tractorland,and for some unknown reason its never made it across the pond
Charlie
02-17-2003 06:44:36
 Re: Re: DB 996 in reply to Brit. 1, 02-17-2003 06:22:53
I too am in the chilly UK and it is a 1978 996 which looks as though it had a pick up hitch at some point in time but for some reason or other (probably a broken rod or something) the workings between the arms and the drawbar have been removed and the drawbar bolted in such a way as to prevent it pivoting.
I would simply like to discover how much has been removed - it would be nice if it was only two rods that are needed to get it all working again.
Charlie
tom
02-18-2003 14:19:58
 Re: Re: Re: DB 996 in reply to Charlie, 02-17-2003 06:44:36
Ito have a 996 minus the pickup hitch but? I have an 885 with the pickup hitch complete and working i think they were the same set up maybe i could take some pics and email them or scan the drawing i have from the parts list i have. email me if you think i can help
