What controls the butterfly valve on the carburator
Robert P
02-16-2003 17:30:49
Just finished cleaning the carburator on my Case VAC. This is a hobby to me and I'm not to good at it, everything seems in place but I can't figure out how the butterfly valve works. Should there be a spring on the throttle shaft to keep the butterfly valve closed ? It's a MS TSX 114 carb.
John
02-16-2003 17:43:21
 Re: What controls the butterfly valve on the carburator in reply to Robert P, 02-16-2003 17:30:49
I am sure that I will be corrected if I am wrong and then we both will have learned something. But the answer is no, it will not have a spring. That is what your governor is for and there should be one on that. That governor is constantly working that butterfly to keep the engine smooth as the field conditions change ever so slightly. A car engine wants to go back to idle when you take your foot off the throttle, that is due to the fact that you want your foot to control the speed, a governed engine you want to be able to set the governor at 1100 rpm for example and have it stay there for the duration of your mowing, plowing, etc. If I get any more technical I will confuse you and me and undoubtedly get something wrong. Good luck, I am restoring a VAC also, they are great tractors.
Kennyp
02-16-2003 20:03:18
 Re: Re: What controls the butterfly valve on the carburator in reply to John, 02-16-2003 17:43:21
John, You are 100 percent correct, but--pickey, picky- there is usally a spring in there some where to work against the governor to make a vairiable speed out of it. Some times between the throtle lever and the governor to butterfly rod. I said picky, picky.
Slowpoke
02-17-2003 00:21:54
 Re: Re: Re: What controls the butterfly valve on the carburator in reply to Kennyp, 02-16-2003 20:03:18
The spring is also used to return the foot feed.
