It's all downhill from here... Case tractor hill climb
Mike Schotte
02-16-2003 07:29:01
Hi All,
I posted this vintage photo to the Tractor Bashing board the other day- but they said it didn't work for them.
I thought that I'd put it up here. I've seen lots of photos of big Case steamers doing the hill climb demonstration at county fairs- but this is the first photo that I've seen of the early gasoline tractors doing it. Looks like the hill is a lot higher!
I enlarged and enhanced the photo (I copied the image from an Ebay auction)- on the banner attached to the ramp I can see Old Abe and "Case" "Hill Climb" and "Power"... but I can't make out what the rest of the banner said.
-Schotte
clint
02-16-2003 15:41:14
 Re: It's all downhill from here... Case tractor hill climb in reply to Mike Schotte, 02-16-2003 07:29:01
Mike The climb was one part of the demonstration. The rest was when they got to the top the trick was to balance the tractor just before it rocked over on the top. The old steamers had a big advantage because they work like hydraulics. It is easy to stop them under power and hold a set position, much like slipping a good ol' wet clutch Case.
Many competitors couldn't do it 'cause the clutches got hot.
Good seeing you at Glenrose
clint
indiana farmer
02-16-2003 10:52:17
didn't you mean 20-40?
Mike Schotte
02-16-2003 13:48:27
 Re: Re: It's all downhill from here... Case tractor hill climb in reply to indiana farmer, 02-16-2003 10:52:17
Oops- I did mean 20-40. Thanks for the catch. I'm assuming that you could view the photo O.K. ?
-Schotte
