Marvel Carburetor on Case VAC
Ray Bosch
02-15-2003 19:10:57
How do I prevent flooding? Can you explain the adjustments I need to make.
Thanks,
Ray
mj
02-15-2003 21:34:27
 Re: Marvel Carburetor on Case VAC in reply to Ray Bosch, 02-15-2003 19:10:57
Check your float , make sure it floats and is not hanging up on bowl sides. Remove float and needle. Inspect the needle and seat for obvious flaws. Check the float setting - Invert carb top casting so that the float lever is in contact with the float needle valve and the needle is seated. 'TSX' 7/8", 1" AND 1 1/2 " models should be set to 1/4" from the gasket to the nearest surface of the float. If the carb still floods don't even bother to look at the needle and seat again just replace them and you should be good to go. To preset needles lightly bottom them and then back idle out 1 1/4 turns, set the high speed needle 1 1/4 out. --continued next post---
mj
02-15-2003 21:36:51
 Re: Re: Marvel Carburetor on Case VAC in reply to mj, 02-15-2003 21:34:27
---continued from previous post---
With engine running set idle speed screw to about 500rpm then adjust idle mixture to smoothest running. Run engine at governed maximum rpm and slowly turn high speed needle in until speed drops off then turn needle out for smoothest running and a wee bit more, in other words 'favor the rich side'.
NOTE: TSX carbs were used on other brands so Ford parts will exchange as will John Deere. I'm sure there are others, as well. None of my VAs have Case floats, needles or seats anymore; they are either JD, Ford, or whatever fits since we don't have a Case dealer anywhere close , now.
