VAC transmission noise
Mike B.
02-15-2003 13:12:03
My VAC has developed a knocking noise in the transmission.It sounds to me like its in the upper part of the trans.The noise sounds the same whether its in gear or not.Do any of you VAC guys have any ideas on what I might be dealing with here?I'm going to have to fix it soon,the snow is piling up.Any help would be appreciated.Thanks,Mike.
Mike from Canada
02-15-2003 14:11:02
 Re: VAC transmission noise in reply to Mike B., 02-15-2003 13:12:03
sounds like one of your gears has a tooth missing. because the gears always mesh between the mainshaft and countershaft, they will always make noise. the gears are selected by use of forks and locking rings. ratios work their way through the clusters depending on which gear is selected.
have fun spitting your tractor in half. its not a quick and easy job.
good luck!
mike
