Case back hoe bucket
Neal in NM
02-14-2003 19:16:12
I have a customer who has recently bought a used bucket from a rental company. One of the pivot bushing holes was buggered up bad. I machined a sleeve to match the other bushing hole and welded it in. The customer shows up with new bushing only to discover that they don't fit. The holes in the bucket are about 2 13/32" and the bushings are 2 1/2". After a long talk with CASE, they told me that it was not made by them. Anyone have any idea who may have made this bucket? It supposedly came off a CASE 580L and the customer wants to put it on a 580C. The bucket is 12" wide and according to case it is their mounting pattern. Please help! Neal
Marc
02-14-2003 21:16:22
 Re: Case back hoe bucket in reply to Neal in NM, 02-14-2003 19:16:12
Neal,
Bucket manufactures usually put their brand on them. You may have a Gannon, Central Fabricators or C & P. Most of the aftermarket bucket manufactures use bushings that are the same as Case uses in their buckets, as well as teeth and shanks. The Case bushing for the main pin (bucket to dipper arm) part number D37495 is 2-1/4 OD x 1-3/4 OD X 1-1/4 W. The bushing in the bucket for the linkage pin, part number D30933 is 1-7/8 OD X 1-1/2 ID X 1-1/4 W. Let me know the dimensions of the bushing you need and I will run it by my pin & bushing vendor if you want.
Hope this helps, Marc
Neal in NM
02-15-2003 07:03:00
 Re: Re: Case back hoe bucket in reply to Marc , 02-14-2003 21:16:22
I already stated the bushing size I need in my first post. 2 13/32 od, 1 3/4 id, 3/4 wide. It is the main pin. Neal
