What's the white powder in my tires?
Steve-IA
02-13-2003 18:53:51
Hi all,
Appreciate any input to help solve a little mystery.
The rear tires on my 49 LA are filled with a very heavy white powder. The inner tubes are still original & they have a 2 inch diameter valve stem. The brass cap that seals the big valve stem has a normal valve stem coming out the middle of that. Anybody ever seen this or know if this is powdered lead? Was this an option on any of your tractors? Was talking with Don L. & he said he never heard of that before. Dad ordered it but I never thought to ask him. Silly me.
Thanks for any input.
Steve Moeller
Steve-IA
02-14-2003 16:41:00
 Re: What's the white powder in my tires? in reply to Steve-IA, 02-13-2003 18:53:51
Everyone,
Thanks for the great input! I believe the consensus is powdered lead.(unfortunately) Also thanks for the safety tips. I just got an operators manual for this thing & it says it weighs 6,700 lbs with nothing in the tires. Back in the early 80's was the last time I had it on a scale & it was well into the 8,000's. Now I'm figuring out that this extra weight is probably the reason I could outpull my brother on Dad's '64 830 (67 hp) on the level farm. Bet he was slipping a bit more cause Dad never put fluid in the tires(we had 2 identical 3-16 Oliver plows) & the 830 could outpull me on the hilly home place. His 6 gears to my 4 killed me there. We could lap each other 2 times in a 16 hour day plowing a 100 acre field depending on which farm. (rules of the game: when one of us stopped the other had to stop immediately, otherwise instant disqualification:). It's nice getting a little reason into the why's 30 yrs later!
Thanks again for the input!
Steve Moeller
Mike from Canada
02-15-2003 14:23:46
 Re: Re: What's the white powder in my tires? in reply to Steve-IA, 02-14-2003 16:41:00
i work in a plastics factory where we manufacture pvc window frame extrusions, and rain gutters. im one of the guys that compounds all of the additives. we used to use powdered lead as a heat stabilizer in our mixes to keep the compound melting rather than burning when being run on the lines. you may have a home for all that powdered lead if you can find a pvc plastics manufacturer who is willing to take it off your hands if youve got a reasonable quantity; that is, if theyre still using lead as a stabilizer. many manufacturers have switched to Calcium/Zinc or Tin stabilizers for health and environmental reasons. lead still works the best though.
good luck!
mike
G Michaels
02-14-2003 08:54:32
Good morning,yes it is lead powder, I had a case 630 that had it,was quite heavier than calcium. The large valve stem kept pulling off tube, wasn't worth the extra weight. Be careful with disposal. Have a good one.
Will
02-14-2003 07:49:55
Don't remember the name of it. Had it put in AC 7050 once for extra weight. Gave me more weight than calicum solution. Don't think it was lead. Was a mess when tire needed changing. No longer have the tractor.
John Ne.
02-13-2003 21:59:04
I've never heard of lead powder in tires, but, when I installed new tires back when, with inner tubes, most of the new tires had a white powdery almost talcum powder stuff inside them to help slip the tubes in, and sometimes when we pulled new tubes out of the boxes, they were coated with talcum powder, in heat, rubber liked to stick to itself. john
Don Rudolph
02-13-2003 21:21:02
Steve,
This sounds exactly like what a good friend of mine described as his worst tire repair nightmare. He said there was about a 2 inch diameter valve stem and the tires were full of some mystery powder which he later found out was lead. The tractor was a 500 Case in North Dakota.
Kennyp
02-13-2003 21:07:52
Oh, OH. Could it be lead powder? There was a couple of years when that was considered the thing to use. If it is, be very careful it is extremly bad stuff. Don't breath it. Never heard of calcium cloride as a powder.
Joe (Wa)
02-13-2003 19:41:48
Hi Steve, white powder may be calcium chloride. Normal solution is about 3.5 lbs/gal of water. A slow leak over a long period in a low duty tractor probably would have quite a bit of salt left behind. Don't know about the valve stem. Regards, Joe
