Injection pump repair-- Where???
Jeff N.E. Wis.
02-12-2003 14:53:52
I have an fuel injection pump off our Case 500 that I need repaired right. I have had it off and to a local pump repair place 3 times and over $500.00 and it still does not work right. Is their any place I can ship it to that does a good job on these old pumps? Any comments will be appreciated. Thanks.
JMS/MN
02-13-2003 23:04:09
 Re: Injection pump repair-- Where??? in reply to Jeff N.E. Wis., 02-12-2003 14:53:52
Mike, Diesel Specialties, Albert Lea, Mn. Area code 507.
Elliott
02-13-2003 19:49:21
Jeff I get my done in Sun Prairie, WI. and they do a good job. Not bad price. Diesel Injection in Sun Prairie
DAVE
02-13-2003 10:15:25
Jeff,
Call Dale at Riverdale Farms 920-295-3278. He can direct you.
david
02-13-2003 06:44:21
Wickliff Diesel Service in Bowling Green, KY, or Lexington Diesel Injection, Lexington. KY. Very satisfied with both, of course I've never paid less than $900.00 either for a complete pump rebuild. Neither one of them will do less than a full rebuild.
Jeff From WI.
02-13-2003 04:55:19
Hi Jeff, try this. Diesel Injection Service,Inc. (608)837-7358 216 Wilburn rd. Sun Prairie,WI.53590 i've good luck with them. Jeff From WI.
MGM
02-13-2003 03:08:47
Found another site for you to look at.
http://www.fuelinjectionpumps.com/
MGM
02-13-2003 03:03:42
Jeff
This is probably one of the best in the state of MN.
Have you tried loosening each fitting on your pump to each cylinder to see if its not an injector or valve problem.?
Rochester Fuel Injection Inc 6430 Highway 63 S
Rochester, MN 55904-8411
Phone:(507)288-8038
Good Luck
Mike
Tom Bush
02-12-2003 19:42:24
Try this guy,or give him a call.I don't personally know the guy or his work but he did come highly recomended. Mike's Equipment 1-800-543-2535 somewhere in Kansas I think. Let me know how it turns out,He might even do an exchange for you. Tom
