Is it worth trying?
Rookie!
02-12-2003 09:33:36
Just found out the head on my 1949 LA Case has a crack in it, and the shop thinks they can fix it with pinning it. I have restored over 50 implements, but never a tractor, so this if foreign ground for me. Is this a common thing to try, and will it hold well enough? I plan on using it on my thresher and doing a little plowing. Help!
scottAR
02-14-2003 10:08:40
 Re: Is it worth trying? in reply to Rookie!, 02-12-2003 09:33:36
My dad's M Farmall had eight ( yes eight) cracks in the head in 1976. The head was repaired with pins and it is still running. I overhauled it in 1999 again and the head is still OK.
Tom Bush
02-12-2003 20:09:53
Well I do know that "INDY HEAD SERVICE" in Indianapolis ,IN rebuilt the complete corner of a Chrysler "Hemi" head,The guy ran it for several more seasons after that.
Tom
02-12-2003 17:25:11
Yes, try the pinning. Forget the $4 glass based block sealer recommended below - you will ruin the radiator, water pump, and may even clog up passages in the block.
Gary
02-12-2003 15:16:03
hey you can always try sealing it with a glass block sealer! whats it going to hurt! its about $4.00 a bottle at your auto parts supply.may or may not work.ask around!good luck
Eddei in Ky
02-14-2003 15:59:25
 Re: Re: Is it worth trying? in reply to Gary, 02-12-2003 15:16:03
Dont try the block sealer. I have and its seals real good, like the man said, it sealed the block, radiator and heater core, it was in a car but the stuff does what it says SEALS
Doug
02-12-2003 16:32:05
I would say yes its worth a try! Its hard to find a good head for that tractor without spending$$$$! I had a head on a Ford 860 pinned in 4 places about 12 years ago and not had any problems1
