VA sediment filter
Ted in Sacramen
02-12-2003 05:34:50
When the gas tank is correctly installed is the sediment filter on a VA type Case positioned to the right rear or left forward on a VA tractor?
Also is the NAPA regulator an accurate aftermarket replacement?
mj
02-13-2003 17:55:44
 Re: VA sediment filter in reply to Ted in Sacramento, 02-12-2003 05:34:50
Of the 7 VAs I've owned all were left front. All the pictures, where the bowl is visible, in my "VA Series Tractor and Engine Service Manual" show the sediment bowl in that position as well.
RnOld
02-12-2003 12:26:55
Left front, at least that's where it has always been on my '51 VA. Seems correct since that way it is on the same side as the carburetor. Don't know about the regulator.
Ted in Sacramento
02-12-2003 16:08:14
 Re: Re: VA sediment filter in reply to RnOld, 02-12-2003 12:26:55
Thanks, it seemed that would be right to me however the tank must have been turned around at sometime during the last 50 some years on this 1948 VAO as it was left rear.
