Powersteering for Case 900B
Ol Chief
02-09-2003 11:28:48
I have two 900B's one on rubber the other on steel.The one on steel is used to plow mesquite roots but does not have power steering.Getting around in wooded areas is tough.Does anyone know of an orginal or after market power steering system to fit this tractor.
caseman-d
02-09-2003 17:46:49
 Re: Powersteering for Case 900B in reply to Ol Chief, 02-09-2003 11:28:48
I'm not positive but I think most ps units of a 500, 600, or another 900 should work. Think lot of the 4 cylinder Case tractors (400,700,800's) had the same steering pump. Looking in my books most took the A10057 pump and then find a cylinder. A 900 on steel, do you have any pictures you can share will the rest of us. I have seen lots of 900 but never one on steel. There was a post couple pages back about someone junking a 500 out. Also might try to contact Don L, he probably has a few lying around.
Ol Chief
02-10-2003 20:51:50
 Re: Re: Powersteering for Case 900B in reply to caseman-d, 02-09-2003 17:46:49
Reply to caseman d Thanks for your input.This tractor is a cosmetic horror so I have never taken any pictures.However I will do so since you asked. I will need some coaching to get them on to this screen later on.The pwr. steering set up on 900 series seems to me to be unique,simple and real effective.The regular steering rod is supplanted by a shorter rod which simply has a small spool valve as a flow director attached by hoses to an short 2inch cylinder.This cylinder push rod is attached to and operates the steering linkage. A really nifty setup. I will take photos of both systems, one tractor has pwr.steering the other is mechanical. Who is Don L address? Tks.
caseman-d
02-11-2003 11:50:27
 Re: Re: Re: Powersteering for Case 900B in reply to Ol Chief, 02-10-2003 20:51:50
Ol Chief.
Don Livingston is in Austin MN, phone 507-433-0073. He has a big selection of Case good used parts. If he doesn't I might know someone that would.
H.W.Murphy
03-24-2004 07:45:57
 Re: Re: Re: Re: Powersteering for Case 900B in reply to caseman-d, 02-11-2003 11:50:27
Your description of a single piston to run power steering sounds like mine on a 63 530, all my books show 2 cylinders and a rotary valve setup on the steering wheel. Mine is mechanical rods down to the Pitman arm? where it connects to the right wheel. Then there is this piston with a small valve block and hoses. One end is fixed to the frame and the other attaches to the left wheel spindle. It is simplistic, not very powerful with a full loader, and it leaks. I have various o-rings packed in to replace the unidentifiable seals and have it only losing a half qt a day but it would be nice to know what it is, what the seal should be, and how it got onto what is marked a 530, diesel, with the 31 backhoe. Any help appreciated.
