Steering problems getting worse.
Jeb Mccranie
02-08-2003 20:01:49
A while back I posted a message on here about my 1290's stubborn steering. Some body suggested checking the power steering fluid and it was a little low so I filled it up. Thats when all the problems started. It sometimes is extremely hard to turn the left (steering cylinder shortens). It feels like the power steering just isnt there but yet it only happens at the most imopurtune moments now matter how warmed up the tractor is.
I almost destroyed a hay ring this morning because of this problem. Really need help ASAP.
Not very fun trying to back my 2590 into the hay ring!
Jeb Mccranie-thganks fo the advice fellas
02-11-2003 14:51:40
 Re: Steering problems getting worse. in reply to Jeb Mccranie, 02-08-2003 20:01:49
Thanks for all the advice guys. I am going to try and harrow up a field this weekend with it.kind o curious to see if the problem will go away once I run it for a bout 2 hours and get it good and hot. Has been an unusuallly cold winter down here in Georgia nad I think that might have something to do with it. Only run the tractor for about 20 minutes when I feed the cows so the engine temperature stays pretty low. I will let you all know something pretty soon.
whats a hay ring
02-10-2003 17:53:03
what is that ???? duh ??
Jeb mccranie
02-11-2003 11:07:36
 Re: Re: Steering problems getting worse. in reply to whats a hay ring, 02-10-2003 17:53:03
it is the ring you put hay inside of to keep the cows from tearing it apart
Les...fortunate
02-11-2003 04:14:25
I was hoping somebody would ask that so that I would know, too. But I guess nobody is going to bother to answer.
Elmer
02-09-2003 08:06:59
Does it steer fine to the right at all times? I am just wondering about pump pressure. There is also a valve in the steering cylinder that diverts return oil from the rod end of the cylinder to the piston side so it extracts at the same speed as it retracts. It may have a problem. There is also a spring in the hand control that returns the steering wheel to its centered position. You can check it by slightly turning the steering wheel. You can feel the spring in it. And it will return the wheel back on its own. Maybe the leaf spring in there is broken. But the symptom for that is steering on its own without you touching the wheel. You could put a gauge in the lines at the cylinder and get a reading and see what you get.
Jeb Mccranie
02-09-2003 10:14:29
 Re: Re: Steering problems getting worse. in reply to Elmer, 02-09-2003 08:06:59
I have noticed that it only happens when I try to make a sudden hard turn. If I let it sit for a few seconds after it does it I can complete the turn. Feels kind of like like it is dragging.
Elmer
02-09-2003 10:27:17
 Re: Re: Re: Steering problems getting worse. in reply to Jeb Mccranie, 02-09-2003 10:14:29
I have never come across this symptom before. I would be in suspicion of the hand pump at the steering column base, but maybe for what it would cost i would take the cylinder apart and inspect it first. Elmer
Jeb Mccranie
02-09-2003 15:10:27
 Re: Re: Re: Re: Steering problems getting worse. in reply to Elmer, 02-09-2003 10:27:17
Is it hard to take the cylinder apart? And what should I look for when I get it apart ? Also, could there be air in the lines ?
kydavid
02-09-2003 17:04:22
 Re: Re: Re: Re: Re: Steering problems getting worse. in reply to Jeb Mccranie, 02-09-2003 15:10:27
Jeb, First let me say Elmer is the expert, I'm at best a novice. Your 1290 has a fluid accumulator if I remember correctly, also could have air in the lines, or a bad leak. Just went through that ( leaking on the pressure out line on the pump, back side, hard to see, and harder to fix. I like to jack up the front end, turn the wheel stop to stop and add fluid as needed. Then set it down after it's turning good and drive, if it gets hard open up and see if fluid is low again, if it is you've got a bad leak (at 1000psi doesn't take long to lose a pint of oil, that's all it takes). Never had a steering cylinder fail except bending a rod. Could blow the packings and be leaking internal or I have had relief valve back out and blow a fitting. Lastly, fluid incomaptability is always a consideration. I use regular THF in all my pumps but one that leaks a little to the crankcase, use engine oil in it. Good luck.
DAB
rhudson
02-09-2003 06:36:33
Hi Jeb,
let me first warn you, i know nothing of 1290's.
once my MF was running low on steering fluid and i refilled it using a funnel. i had used the same funnel a couple of days before to pour 90w oil into a gearbox. the heavy oil residue left in the funnel stopped up the powersteering suction screen. i took off the powersteering tank and screen, back flushed with carberator cleaner and it worked fine.
Just thinking it might be your problem.
