Case 730 won't roll
Jonathan Anders
09-26-2006 07:27:15
I purchase a Case 731 for salvage from a man the other day that has been sitting for probably ten years outside. When he tried to move it to load it up, the rear wheels will not move at all. He said it is the standard transmission and that he had it out of gear. What else would cause it to stick and not roll? Brakes rusted up? What do you all think?
Patrick (Mich.)
09-26-2006 22:10:14
 Re: Case 730 won't roll in reply to Jonathan Anders, 09-26-2006 07:27:15
I'd also guess that the brakes are at fault. Case brakes on that era of tractors seem to be prone to rusting if the tractor is parked outside. The 730 I purchsed which had been outside for multiple years (enough to seize the engine) did not suffer from rusted brakes, but only because the shaft seals had failed years ago, and the brakes were thoroughly covered in oil. However, a 310B parts tractor that I recently moved after sitting out for about 5 years did have one wheel brake seized. I could only free it by rocking the tractor back and forth on a concrete drive with the other wheel brake applied.
texaswren
09-26-2006 09:02:40
I'd guess brakes. If it's out of gear, there's not much else that could possibly have gotten stuck while it was just sitting (unless of course, the tranny cover leaked, and it filled up with water, displaced all the oil out and rusted up solid!) Fortunately, it's really easy to pop the brake covers and check them.
