More comments on 2590 Case...
Steven@nd
02-08-2003 02:11:50
Whoever said that you can't pull Case tractors at rated HP is wrong. The 2590 is rated at 180 PTO horsepower. The guy we bought ours from had the engine rebuilt and it put out 205 horses on the PTO before being broke in!
Fuel consumption: I start in the field around 5 or 6 am on a good day. We pull a 26 foot anhydrous applicator (26 spikes) - that's when it uses the most fuel pulling at 6 mph (tranny in 3, PS in 2) full throttle. We also use it to pull 28 feet of IH 7200 hoe drills, that only takes about 2/3 throttle and 4 mph, pulls it easy. On the baler it will run all day on a tank easily.
Has 20.8x38 radial tires, duals, chloride, cast iron weights and cast iron wheels on the duals too. Also has 10 or so front end suitcase weights. It could actually use a little more weight on the rear end as it slips pulling the anhydrous applicator.
It has about 5700 hours on it with no major problems since new (we are the 3rd owner). The last owner rebuilt the engine because it burned a quart of oil every 50 hours (he was picky) and also had the transmission updated.
We would like to find another one someday (2590 or 2390) to use as a loader tractor and haying tractor. Just relaying my experience with a 90 series Case tractor...
third party image
Foxtail
02-08-2003 22:23:21
 Re: More comments on 2590 Case... in reply to Steven@nd, 02-08-2003 02:11:50
Still have a 2590 that was purchased new in 1979. Think these were some of the nicest looking tractors any company ever built.
Jeb Mccranie
02-08-2003 19:53:07
Nice picture. I have owned a 2590 for several years and it can pull a 6-8 bottom plow through georgia red clay in 2nd gear. great tractor but wish I had a set of duals
Wade Burt
02-13-2003 09:16:11
 Re: Re: More comments on 2590 Case... in reply to Jeb Mccranie, 02-08-2003 19:53:07
I have a set of Duals to fit your 2590 with 20.8x38 radial rubber on the rims the tires may or may not be good I also have a pair of 12 inch spacers. I will take 600.00 for duals , hubs and spacers or 500.00 for duals and hubs.
Wade Burt 1270 HWY. 32 east Houlka, MS 38850
Big Orange
02-08-2003 14:12:06
Steve,I've got a 2390 bought new in 1983,only breakdown was a torquelimiter,put in a 94 series and has been fine every since.Pull a 25' disk and a 26.5' field cultivator in 2nd gear 3rd range,pull a 9 shank disc chisel 12" deep in 3-2,and it will run 13hrs. on a tank of fuel.
Jerry
02-08-2003 12:59:20
Steve, I bought a 2390 last year and what a tractor. I was pulling a DMI 1000 5 shank sub soiler in 3-3 and kept breaking bolts in the DMI. I know this Ohio lake bed clay is tuff but this tractor is tuffer.
Whip
indiana farmer
02-08-2003 11:19:39
back when i worked for the local case dealer all 2390's 2590's came from the plant with 30 to 40 more hp than they were rated! the 94 series were the same way. the 2394,2594 3394, and 3594 with the 6 speed powershift was the smoothest and best powershift on the market. i always liked it better than the magnum powershift. thats my two dollers worth.
SHeiserman
02-08-2003 09:34:31
Nice. We used 2390 for years here. It was THE horse in a partnership between two guys. The hard work it did was a 5 shank M&W Earthmaster in the fall. Work it all day and night, nary a problem. The guy that owns it is my father in law. He gave up farming and I hate to see it go.
Larry in AB
02-08-2003 07:26:07
I pull a morris 25ft field cultivator with my 2090 in 2nd gear and 3rd powershift. I believe for constant heavy pulling you suppost to run it in 3rd powershift as thats direct drive no reduction.
It really has to work hard though and has trouble on hills. But its been pulling it for 15 years so far. I don't pull the cultivator as much anymore as I notill mostly now. So it has to pull a 15ft Great plains notill drill which is pretty easy unless the ground is soft and it has traction problems. I'd like to get something a little bigger like a CIH 7110 someday they look like a good machine.
Shane
02-08-2003 09:43:36
 Re: Re: More comments on 2590 Case... in reply to Larry in AB, 02-08-2003 07:26:07
We used a 15ft Great Planis no-till drill for years behind a 1070, which is same as a 2090 power wise. I pulled it in 3rd 3rd at 1500 rpm's and it worked just fine except the steep hills. Changed to a 20ft this past year and still can pull that in 3rd 3rd. Of course we use duals for traction. Would like to use our 1270 but cant get my dad to give it up!
Shane
02-08-2003 06:59:18
That is one pretty tractor. Love to find one like that around me.
Marvin
02-09-2003 17:17:47
 Re: Re: More comments on 2590 Case... in reply to Shane, 02-08-2003 06:59:18
Personally I wouldn't touch an old Case with a 10ft pole! Those things were a nighmare with the rear ends and trans problems.
You all must be fantastic mechanics because you have to fix on them lots!
JMHO
John H
02-10-2003 18:24:54
 Re: Re: Re: More comments on 2590 Case... in reply to Marvin, 02-09-2003 17:17:47
Geez Marvin, what do the John Deere dealers do in those huge shops they all have? Maybe they just store fuel trucks in them to go out and fuel up the mean green machines so the farmers don't have to come home at noon to fill those guzzlers up!
Shane
02-10-2003 07:04:16
If you havent noticed, almost everybody with a Case says they are reliable tractors, including myself. We have never had any tranny or rearend problems. You must be a John Deere guy or something.
