Case power unit
Joe in Ohio
02-07-2003 17:40:16
Anyone in Case land ever seen a R-series power unit? I bought one and would like to know more about it. It's the same motor,radiator and fuel tank as my 1938 RC Case. I did find it was used on the model K combine in the 1930's. The brochure showed a close up of the power unit but gave no info about it. Would this be called an RE ?
CASEPOWER
02-07-2003 19:45:37
 Re: Case power unit in reply to Joe in Ohio, 02-07-2003 17:40:16
Case used a lot of waukesha engines on Combines. I have a Waukesha power unit off of a water pump and it is identical also. The insides were better. It had inserts, flat top pistons, and a higher comp. head. It was a FK and the RC was a FC if I remember right. Does your unit have a radiator?? If so does it say Case or Waukesha on the top tanl??
Joe
02-07-2003 20:51:59
 Re: Re: Case power unit in reply to CASEPOWER, 02-07-2003 19:45:37
The radiator does say Case. The hood has the raised Case on both sides.
CASEPOWER
02-08-2003 07:52:27
 Re: Re: Re: Case power unit in reply to Joe, 02-07-2003 20:51:59
Is it forsale??
Joe
02-08-2003 08:01:21
 Re: Re: Re: Re: Case power unit in reply to CASEPOWER, 02-08-2003 07:52:27
Sorry,not for sale. Thought I'd get it painted and put a set of wheels under it to show with my 1938 RC.
CASEPOWER
02-07-2003 19:45:24
