DC pistons
James
02-07-2003 16:03:08
I took the head off a DC parts engine today to check the pistons and sleeves. The engine is out of a 1952 it has the 5576 cyl head which is the low compresion head. What i am curious about is the pistons lack 1/4 or so from the top of the sleeves. They are 3 7/8 bore and very very good but i have never seen them not come to the top. I have a C that they stick up out of the block a hair. I have tore down several with the low comp head but the pistons always came up to the top. Thanks for any thoughts.
Jim M
02-07-2003 16:42:01
 Re: DC pistons in reply to James, 02-07-2003 16:03:08
I'm not sure about the 3 7/8" pistons but with the 4" pistons Case DC could have low compression pistons that are 1/4" below the top of the block when all the way up and high compression pistons that come even with the top of the block when at the top of the stroke. I thought most with the 5576 head had the high comp. pistons. My Dc has 4" low comp. pistons with a 5505 head. I have a set of high comp. pistons and am thinking of changing them.
CASEPOWER
02-07-2003 19:52:04
 Re: Re: DC pistons in reply to Jim M, 02-07-2003 16:42:01
The 3-7/8 are the same. The "High Altitudes" stick up about 1/8 inch and the stock all fuels are 1/4 down. The High Alt. are to be used with the low comp. head. If you put the gas head (5505) on with High Alt. pistons you have to mill .040 off the top of them. If not they will hit the head. That is with a Felpro gasket. You may have to take more off if the gasket is thinner. .020 wont get it. I tried and it done fine till it got up to running temp then they tapped on the head a little.
