VAC gear pump
Mike B.
02-05-2003 16:04:49
I'm trying to install an engine driven gear pump on my 47 vac.My local case dealer told me that the newer pump would fit an older tractor.It goes in about half way,and stops.It acts like the gears won't mesh all the way.Has anybody out there had this problem,or have any suggestions?Any help would be appreciated.Thanks
Joe (Wa)
02-05-2003 17:59:07
 Re: VAC gear pump in reply to Mike B., 02-05-2003 16:04:49
Hi Mike, If this pump mounts on the front right side of the engine > from the parts manual: pumps prior to engine serial nr A4700000 have 7/8" wide drive gear. Pumps after engine serial A4700000 have 1-1/16 wide drive gear. That applies to both distributor ignition and mag. Engine serial nr is on the block just above the starter. Joe
mj
02-08-2003 07:35:20
 Re: Re: VAC gear pump in reply to Joe (Wa), 02-05-2003 17:59:07
A note of caution: These pumps are lubricated by the flow from the intake side of pump and should never be run without adequate oil supply.
