Thanks for sending it, John. I'm looking forward to reading the article about your SC, and I'll scan the photos for you as soon as I can. I went out to visit my two "parts" SCs over the weekend. Did another "burn" on the '45 with the head removed. I used diesel this time instead of Marvel Mystery Oil. Seemed to burn a lot hotter and a lot longer. There was about 1/16" of soot on the studs and sleeves when it finished burning. While everything was still nice and hot- I brushed everything clean with a small brass brush. I did a little tapping on the pistons with a piece of wood, and then added more diesel to let it soak for another couple of weeks. We'll see. The stuck valve on the '49 is STILL stuck... despite all my soaking. The only thing is that now it's ALL THE WAY down. I tried Robert Kelley's rope trick- and stuffed as much nylon rope down the spark plug hole as I could get to go in there. However- I wasn't able to push the stuck valve up by rotating the engine. I could only go so far with the hand crank, and then I would have to turn the engine 'round backwards with the belt pulley in order to have another go at it. Well- found out ONE interesting thing... the engine wasn't completely unstuck before- but NOW it is. I turns out that there's enough clearance for the pistons to go through a cycle WITHOUT hitting the valves. (who knew?) The engine spins very freely now- not that it's doing me any good. I would really like to get this girl running and evaluate what ELSE might be wrong with it before I start messing with pulling the head and buying new head and exhaust gaskets. It's not silly to want to know if this is truly a "parts" tractor before I sink another couple of hundred buck in it, is it?? (grin) -Schotte
