Steering cylinders leak on 430LCK
Roger
02-03-2003 10:54:20
I have a 1963 430LCK and the steering cylinders leak very badly. Does anyone have any experinence in the removal and re-sealing of these cylinders? It appears that the entire front axle and steering assembly must be dropped away from the tractor so that the cylinders can be removed and serviced. Looks like the steering pivot within the steering cylinder frame must also be disassembled. Does this sound correct?
There is no pitting or scratches on the cylinders so I think the re-seal kit from Case should correct the problem. Any help or suggestions would be great.
