VAC Carb troubles
Larry K. Noller
02-01-2003 18:15:51
It seems that the carb on my VAC has some problems that I can't seem to solve. It is a Marvel-Schebler TSX. I have to put my hand over the carb throat to get the thing to start and the only way that it will run is by screwing the smaller adjusting screw all the way in tight and it doesn't make any difference where the larger adjustment screw is set, as a matter of fact I can take it out of the carb while it is running with no effect at all. It will idle like a champ and runs fine at 1/2 throttle but will not
run at high speeds. I have put a full kit in it and it appears to be clean as a pin inside. (It was set as I described when I bought the tractor)
It is getting plenty of fuel into the carb. Beats Me.
Larry
C. Amick
02-04-2003 14:30:48
 Re: VAC Carb troubles in reply to Larry K. Noller, 02-01-2003 18:15:51
Were there instructions with the carb. kit on setting the float level? If nothing is plugged, float could be set too low and it is starving for fuel.
Casedude
02-03-2003 17:49:42
Its hard to get carbs to come clean after sitting. We took a carb apart and soaked it in really strong carb cleaner. I forgot the name but i am sure someone can tell you. we got it at napa or some auto store. Its expensive but worked really well.
casenut
02-02-2003 07:15:20
Hi Larry,
I'm sure what your going to find that the fuel venturi is plugged. Reason being when you turn the small screw all the way in that will shut off all the air and will not matter where the large on is because it is already restricted. (the large one is for the fuel and the small one is for the air). Take the carb apart and either blow out all the holes or use a very small piece of wire to poke them out. Hope this helps.
rustytractor
02-02-2003 06:11:23
Did you replace the float when you rebuilt it? Sort of sounds like it is flooding. Check to see that the float doesn't have a small leak which would allow fuel to get into it and thus cause it to sink. Hope this helps. Good luck.
