Eagle hitch
Farmall Daddy
02-01-2003 17:48:29
Will the eagle hitch hook up to a 3 pt. grader blade?
Josh
02-02-2003 16:01:52
 Re: Eagle hitch in reply to Farmall Daddy, 02-01-2003 17:48:29
Yes it will. It has to be the right size to fit on the eagle hitch arms though. Use a 7' blade on my 630.
Paul f
02-02-2003 06:34:26
I use a 7' Farm King blade (Cat 1) on my DC3 Eagle Hitch. Wish it would lift up a bit higher but it works OK
GeoMo
02-03-2003 04:42:17
 Re: Re: Eagle hitch in reply to Paul f, 02-02-2003 06:34:26
Adding an addional hole above the existing on the third link on the blade will make it rase higher, however it will not raise level.
Richard
02-02-2003 19:48:55
On DC and SC if you put your toplink on plow mount ( the one that fits over the pto ) it will lift higher.
Paul F
02-03-2003 05:25:20
 Re: Re: Re: Eagle hitch in reply to Richard, 02-02-2003 19:48:55
Thank you both for the ideas (now I need to get a PTO cover and mount :-)
Ron
02-01-2003 21:03:15
Depends on what kind of blade you have. I have a Gill blade and it won't fit my 311. I could modify it to fit fairly easy but I just use it with other tractors. The 311 is a great little tractor to use a blade because of the quick hydraulic controls. I may modify mine to fit it someday.
Larry
02-01-2003 20:02:36
As long as the blade is a catagory one and you have te parts for the top link for the tractor it should work.
george md
02-01-2003 17:59:58
sure will , I have blade frame with landscape rake on it that I have been using for 35 years.Use it on 300 round grille or 730 diesel .
george
