SC Rod Journals and Piston Rings
Rob G
02-01-2003 17:11:16
I am restoring a 1950 Case SC and need two pieces of information:
1) The crankshaft rod journals need to be turned. From the service manual I calculate the factory rod journal to be 2.375 inches +/- .0005 inch. Is that correct? I measured the rod journals at 2.370 inches. Is it possible they have worn 5 thousands or have they likely been turned before?
2)The engine has been rebuilt before with MW 3 11/16 aluminum pistons. Can anyone give me the specs for these pistons/rings, i.e. ring groove widths, ring thickness, ring clearances & gap, etc. Also, where can I get new rings for the MW pistons?
I would really appreciate your help. Thanks in advance. Rob
Rob G.
02-03-2003 15:36:12
 Re: SC Rod Journals and Piston Rings in reply to Rob G, 02-01-2003 17:11:16
Thanks for your help guys. That's the information I needed. Rob
Earl S
02-02-2003 17:50:42
Federal Mogul Brg # for SC case rod brg is 1370SB Std crank spec is 2.3745---2.3755 Hasting ring set for M&W 3.11/16 bore is 2C7941 It has 12- 3/32 comp rings and 4- 3/16 oil rings.Your ring end gap will depend on how much wear is in the sleeve. Check your ring in the btm of the bore below the ring travel.How much wear in the sleeves??? Earl
george md
02-01-2003 17:55:42
Rob, crank very well could be worn .005 , probably not round either . Sealed power has rings .
Part # 5486KX for 3 11/16 bore.
george
