What is a Powershift transmission ?
Jeb Mccranie
01-31-2003 14:33:58
Please excuse my ignorance, but exactly what is a powershift transmission ? And howcome my 2590 has a manual transmission ?
JMS/MN
02-01-2003 23:58:18
 Re: What is a Powershift transmission ? in reply to Jeb Mccranie, 01-31-2003 14:33:58
A powershift transmission allows you to shift betwen gears without clutching. Case has a powershift with four ranges. Pick the range and go 1-2-3 in that range. JD has an 8 speed and more recently a 15 speed power shift, no ranges. One lever controls the shift between all speeds. I've had 8 and 15 speed PS for over 29 years on five tractors and would never go back to all gear drive. Also have a 2470 Case with 4 range tranny and 3 PS. Yes, PS takes a few more HP to operate, but the advantage of PS more than makes up for the power loss- maybe 4 hp on 100. I'll take JD over Case any day.
Jeb Mccranie
02-02-2003 11:05:57
 Re: Re: What is a Powershift transmission ? in reply to JMS/MN, 02-01-2003 23:58:18
I don't know about you but would never replace my 2590 with a John Deere. Besides, has over 10,000 hours and have not had a problem yet.
John H
02-02-2003 02:08:34
The newer John Deeres have more than 15 speeds as they bumped them up when Case went to 18. The two major things JD had over Case is price and fuel consumption. IN these two catagories they beat Case hands down. If you want to have a little chuckle check into the time JD upped the gear selection to beat Case.
ed crankcase
02-01-2003 04:16:50
your 2590 has a power shift transmission. 4 ranges, 3 power shifts. what case called a 12 speed power shift. now it is not a full power shift (in line) like a magnum. but it is a power shift transmission.
howard s.
01-31-2003 15:16:37
Jeb, I'll leave it to someone else to exlain the inner workings of the transmission, but simply from the operator's standpoint, it is the ability to shift without clutching. I have owned two PS tractors, JDs 4640 and 4840, and I didn't really care for it. They were not smooth shifting at all, and they require lots of power to operate. A PS 3020 couldn't whip a loaned out mule. I don't know what the cost/benefit is on some of this stuff, not only on PS, but also on MFWD. Regards, howard s.
