Randy, Not to worry! M/S carbs are amomg the easiest to understand and work on. First, confirm that the fuel system is clean from the fuel filter to the carb bowl. Take the carb apart again, and use Carb and Choke Spray and compressed air to blow out the carb orifices and fuel inlet to the needle and seat. Be sure to clean the fuel line back to the filter as well. Dripping is usually caused by just a few things. Dirt caught between the needle and seat, the seat gasket leaking, or fuel leaking past the gasket on the main nozzle. (The main nozzle is the long brass tube which is threaded into the lower body at an angle) There is a small fibre washer that seals the main nozzle to the lower body. Replace it and make sure the nozzle (tube) is tightened snugly. (but not too tight, as it is brass) I use a screwdriver type nut driver for this. Check the float setting (1/4" from gasket to nearest part of float - and remember, do not force the needle into the seat while adjusting the float) Then assemble the carb using a new gasket between the halves. Check your primary adjustments - (1 turn out) and you should be good to go. You did the right thing by installing an inline filter. It can save you much aggravation down the road. Good luck! Scott
