P-b blaster
mike o.
01-31-2003 10:04:28
i've seen numerous kinds of products and solutions to froze motors on this board. can anyone please give the names of those products that would work best in this cold weather. the motor has been inside for 8 to 10 years froze. nothing done to it to free it. thanks mike o.
Chris Vangel
02-01-2003 15:55:15
 Re: p-b blaster in reply to mike o., 01-31-2003 10:04:28
I have different types of penetrating oil. Not so much the kind as what I did with it that surprised me. I filled the cylinders of an engine that had been stored inside but still locked up. This will only work on the cylinders that the valves are closed on. Once full of oil, I then took a compression tester hose and hooked it to my air compressor. It forced the oil to the rings and past them through the ring gaps. Engine was freed in no time at all. Refill and let soak if it doesn't work the first time. Good luck. Chris.
Joe (Wa)
02-02-2003 12:22:07
 Re: Re: p-b blaster in reply to Chris Vangel, 02-01-2003 15:55:15
Same here Chris. Take rocker arm off, valves will close or, at least, you can work on freeing them up and get some pressure in the combustion chamber. Joe
Dr Cy Kosis
01-31-2003 18:25:37
I've never heard of it being used for freeing a stuck engine, but the product you mentioned (P B Blaster) has been amazing to me. I'd seen it on some of the Hot Rod and Car restoration TV shows and decided to try it when I saw it at the auto parts store while in search of some 'knocker-loose-juice'.
I soaked all the bolts on the radiator of my current project and was able to remove all but one bolt after 74 years of rusting. Even the upper and lower tank bolts came out without a hitch. I only broke one bolt and it only broke because there was a crack in the water neck leading directly through the bolt hole. I don't think anything could have saved that one since the bolt shank was rusted partially in two.
I grew up using "Liquid Wrench" but I'm a believer in that P B Blaster now. I believe I'd try it for breaking an engine loose too.
Gene Dotson
01-31-2003 17:11:52
Mike; I have had good luck with Coca Cola. I freed the engine in my Vaiw, VAC and an Allis B. All of these had sat for at least 10 years. All 3 of these were turning within 10 minutes. Gene
INCase
01-31-2003 12:31:42
I have a froze motor (730gas) myself. have had trans fluid in it for a year now with no luck (no time to mess with it either). I'm am trying to get some electric transformer oil to try. I've heard from a couple places it works well. I guess its a type of REAL thin mineral oil. Use the search feature on this site. the thiner the better for cold weather. Post what you find works. Good luck!!
mike o.
01-31-2003 20:46:25
 Re: Re: p-b blaster in reply to INCase, 01-31-2003 12:31:42
thanks guys! i'll give it a shot and see what happens!
Casedude
02-02-2003 20:28:34
 Re: Re: Re: p-b blaster in reply to mike o. , 01-31-2003 20:46:25
My dads used that transformer oil because its really really thin and its worked great. I have used PB blast on freeing a stuck 5 hp briggs motor on a till thats sat out side with out a sparkplug. Let it soak and it turned right over the next day. GOod luck
