The VAH
CASEPOWER
01-30-2003 08:29:35
All VAH tractors had drop bull gear boxes. They were made for vegetables and not for Cane work. Stahl was the engineer that came up with it. They used the same trasmission housing. They took the rear housing off of a VA and bolted the drop boxes were the brakes are and the axle went through the center of the brake system. This made the tractor about 10 inches shorter. They used 36" and 38" rear rims. When Clausen approved Stahl's design the other engineers didn't approve because the rear axle housings had to be removed to service the brakes. There was no special equipment made for the VAH. The drop housings are what make a VAH a high crop and I am sure that one coming out of the factory without drop housings would not have a High Crop Tag on it.
